Chrome pit price list
Item Name   Description   Approx. Cost
Air Cleaner Cover (S. Steel) Polish Only   $55.00
Air Cleaner Cover (S. Steel)   $70.00
S&S Air Cleaner Cover   $70.00
S&S Cleaner 2 throat   $30.00
Air Cleaner Backing Plate   $6.00 - $8.00
Axle Spacer   $22.00
Axle With Nut   $10.00
Axle Nut Cover   $10.00
Back Rest   $70.00
Back Rest Brackets   $30.00
Battey Base Plate   $45.00
Battery Box   $65.00
Batter Box Side Cover   $65.00
Battery Box Strap   $24.00
Batter Top   $35.00
Bearing Cup   $30.00
Belt Drive   $125.00
Bolts (Threaded Not Plated)   $3.00 - $4.00
Brackets (Depends on size)   $8.00 - $35.00
Brake Arm   $25.00
Brake Backing Plate   $75.00
Brake Bracket (Rear)   $45.00
Brake Disc (Polished)   $120.00
Brake Drum (Alum)   $90.00
Brake Drum (Steel)   $90.00
Brake Pedal   $30.00 - $45.00
Brake Pedal Mount   $30.00 - $75.00
Brake Rod   $24.00 - $40.00
Brake Rod Parts EA   $8.00
Brake Side Plate   $30.00
Brake Caliper (Front 2 PCS)   $65.00 - $75.00
Brake Caliper (Rear 2 PCS)   $75.00 - $90.00
Brake Caliper Mount (Boomerang)   $35.00
Brake Lever   $30.00
Carburator Body   $90.00
Carburator Bowl   $40.00
Carburator Bracket   $25.00 - $40.00
Carburator Linkage PCS   $10.00 - $15.00
Cam Cover (Early Style)   $120.00
Cam Cover (Nose Cone)   $80.00
Chain Adjuster   $10.00
Chain Guard   $60.00 - $120.00
Choke Lever   $10.00
Clamps EA   $8.00 - $10.00
Clevis   $8.00 - $10.00
Clutch Arm   $30.00
Clutch Pedal   $35.00
Clutch Plate   $35.00 - $40.00
Clutch Lever   $24.00
Coil Bracket   $25.00 - $35.00
Coil Cover   $30.00
Crash Bars (Small)   $50.00 - $75.00
Crash Bars (Large)   $130.00 - $160.00
D-Rings   $35.00
Dash (Die Cast)   $125.00
Dash (Steel)   $95.00
Derby Cover (Aluminum   $35.00
Derby Cover (Steel)   $45.00
Disc   $130.00
Distributor Case   $25.00
Distributor Top   $24.00
Distributor Cup   $24.00
Dip Stick   $15.00
Dust Cover   $12.00
Engine Cases (Polish Only)   $350.00
Engine Cases (Chrome)   $700.00
Exhaust Brackets   $26.00 - $36.00
Exhaust Clamps   $15.00 - $20.00
Exhaust Shields   $25.00 - $50.00
Fender   $75.00 - $150.00
Fender Guard   $48.00 - $90.00
Fender Struts   $45.00 - $75.00
Fender Tip (Two Tone)   $75.00
Fender Tip (Plain)   $30.00 - $55.00
Fittings   $4.00 - $8.00
Floor Board Bracket   $30.00 - $75.00
Floor Board Mount   $45.00
Foot Board (Steel)   $40.00
Foot Board (Aluminum)   $45.00 - $60.00
Foot Pegs   $24.00 - $30.00
Foot Peg Mount   $25.00
Foot Shifter   $35.00 - $50.00
Foot Shifter Cover   $30.00
Fork Stem Cap   $15.00 - $20.00
Fork Tube   $75.00
Fork Tube Cap   $20.00
Frame   $500.00
Gas Cap   $25.00
Gas Tank   $225.00 - $400.00
Gas Tank Cover   $85.00
Gas Tank Emblems   $25.00 - $60.00
Gear Shift Lever   $30.00 - $45.00
Generator Band   $14.00
Generator End   $27.00
Generator Housing   $45.00
Hand Lever   $28.00
Handle Bar   $60.00 - $120.00
Handle Bar Clamp   $15.00
Handle Bar Grips EA   $30.00
Handle Bar Mount   $35.00
Handle Bar Parts   $20.00
Handle Bar Half   $25.00 - $70.00
Headlight Mount   $40.00
Headlight Rim   $40.00 - $60.00
Headlight Shell   $60.00
Headlight Half (Aluminum)   $100.00
Horn Cover   $40.00
Hub (Aluminum)   $95.00
Hub (Steel)   $65.00
Hub Starwasher   $15.00
Inspection Cover (Aluminum)   $25.00
Inspection Plate   $25.00
Instrument Bracket   $48.00
Intake Mainfold   $45.00 - $120.00
Kick Arm   $30.00
Kick Pedal   $30.00
Kick Spring   $12.00
Kick Stand (Side)   $35.00
Kick Stand (Socket)   $22.00
Kicker Cover   $70.00
Knucklehead Cover   $30.00 - $70.00
License Plate Bracket   $30.00 - $55.00
Lifter Block   $35.00 - $65.00
Lower Leg EA   $100.00
Lower Leg End Cap   $10.00
Luggage Carrier   $65.00 - $150.00
Magneto Mount   $18.00
Magneto Body   $45.00
Master Cylinder And Top   $80.00
Motor Mount (Top)   $35.00
Mouse Trap (Aluminum)   $35.00
Mouse Trap (Steel)   $25.00
Mouse Trap Spring   $8.00
Muffler Bracket   $35.00
Nose Cone   $95.00
Nuts   $3.00 - $5.00
Oil Cooler   $55.00
Oil Filter   $45.00
Oil Line   $25.00 - $40.00
Oil Pump (Alumininum, 2 PCS)   $120.00
Oil Pump (Steel, 2 PCS)   $120.00
Oil Tank   $110.00 - $170.00
Oil Tank (Aluminum)   $130.00 - $190.00
Oil Tank Cap   $25.00
Pet Cock   $35.00
Pipe Guards   $24.00 - $45.00
Pressure Plate   $35.00 - $55.00
Pimary (Inner)   $160.00
Primary (Outer)   $160.00
Push Rod Tubes (4 PCS)   $60.00
Push Rod Tubes (12 PCS)   $95.00
Regulator Brackets   $35.00
Regulator Cover   $30.00
Riser (2 PCS) And Cap   $66.00
Rocker Boxes   $120.00
Rocker Shaft Caps EA   $15.00
Saddle Bag Holders   $55.00
Seat Rail   $75.00 - $125.00
Seat Spring EA   $22.00
Shifter (Back Side)   $30.00
Shifter (Front Side)   $30.00
Shifter Gate   $30.00
Shifter Rod and Clevis   $30.00
Side Stand   $30.00 - $40.00
Signal Light Bar   $45.00
Sissy Bars   $95.00
Shock   $40.00 - $55.00
Shock Cover (S.Steel)   $30.00
Shock Adjuster Part   $25.00
Side Rails (Single Tube)   $25.00
Skid Plate   $35.00
Spacers   $8.00
Springs   $18.00 - $30.00
Springer (2 PCS)   $140.00 - $190.00
Speedo Housing (Steel)   $85.00
Speedo Housing (Zinc)   $125.00
Spokes & Nipples EA   $5.00 - $8.00
Spotlight Bracket   $40.00
Sprocket   $75.00
Sprocket Drum   $120.00
Star Washer   $15.00
Starter End Cap   $12.00 - $18.00
Starter End Cover   $30.00
Starter Housing   $40.00
Stablizer Bar   $22.00
Steering Cover (Aluminum)   $35.00
Swing Arm   $150.00 - $250.00
Swing Arm Bolt And Nut   $22.00
Swing Arm Busing   $24.00
Swing Arm Ends   $15.00
Switch Box Controls   $25.00
Tag Bracket (3 PCS)   $42.00
Tail Light Housing   $30.00 - $45.00
Tail Light Bracket   $40.00
Tappet Guide EA   $65.00
Tappet Guide (Aluminum)   $75.00
Tappet Guide (Aluminum, Single Piece)   $30.00
Timing Cover (45 Style)   $120.00
Tool Box and Lid   $90.00 - $150.00
Trans Mounting Plate   $35.00
Trans Lever   $30.00
Trans Casing   $200.00
Trans Side Cover   $75.00
Trans Top Plate   $75.00
Tree Lower   $85.00 - $110.00
Tree Lower Cover   $45.00
Tree Upper   $85.00 - $110.00
Tree Nut   $10.00
Valve Cover (Pan Head) EA   $85.00
Washer   $2.00 - $6.00
Wheels   $300.00
Windshield Bracket   $75.00
Windshield Bracket (Adjustable)   $35.00
Windshield Bracket (L-Shaped)   $40.00
Cam Cover   $165.00
Centre Stand   $80.00 - $105.00
Gear Box Cover   $170.00
Gear Box End   $85.00
Primary   $165.00 - $200.00
Primary Plug   $20.00 Chrome Pit
Just another choice
Spacecoast Plating        in Florida
Dealer Price List
A-M view N-Z
ACORN HEAD BOLTS 3.50 EXHAUST BRACKET 20.00
ACORN NUTS-starts at 2.50 EXHAUST FLANGES 10.00
AIR BOX-aluminum 65.00 EXHAUST PIPES-per foot 25.00
AIR CLEANER BACK PLATE 40.00 FENDER BRACE 45.00
AIR CLEANER COVER 45.00 FENDER SPACERS 20.00
ALLEN BOLTS-starts at 2.00 FENDER STRUTS(ALUM) 50.00
ALUMINUM SPACERS-start at 3.00 FENDER STRUTS(STEEL) 45.00
ALTERNATOR HOUSING 45.00 FENDER TIP(POT METAL) 45.00
AXLE W/NUT 22.00 FENDER TRIM(S/S) 23.00
AXLE ADJUSTER 20.00 FENDERS-start at 150.00
AXLE CAPS-start at 12.00 FERRING BRACKETS 40.00
AXLE SPACERS SML start
AXLE SPACERS MED
AXLE SPACERS LG
AXLE SPACERS Y2K 3.00
4.00
5.00
6.00 FERRING BRACKET CAPS 8.00
BANJO BOLT 3.00 FLOORBOARDS(ALUM) 45.00
BATTERY BOX-bottom 35.00 FLOORBOARDS(STEEL) 40.00
BATTERY BOX-side 30.00 FLOOR BOARD MNT.BRKT(LG) 48.00
BATTERY BOX-strap 23.00 FLOORBOARD MNT.BRKT(SM) 25.00
BATTERY BOX-top 25.00 FOOT PEGS-start at 15.00
BATTERY BOX-cover 40.00 FOOT PEG BRACKET 25.00
BEARING CUPS 15.00 FOOT PEG EXTENTIONS 15.00
BELT GUARDS-start at 50.00 FOOT PEG STUDS-start at 8.00
BLEEDER SCREW 2.00 FOOT PEG STUD BRACKET 15.00
BRAKE BACKING PLATE(ALUM) 70.00 FOOT PEGS(2PC) 25.00
BAKE BACKING PLATE(STEEL) 50.00 FRONT FORK(SPRINGER)LG. 285.00
BRAKE CABLES-start at 30.00 FRONT FORK(SPRINGER)SM. 135.00
BRAKE CALIPER-1PC 55.00 GAS CAPS 20.00
BRAKE CALIPER MNT BRKT 75.00 GENERARTOR BODY(3PC) 75.00
BRAKE CLEVIS 10.00 GENERATOR END CAP 25.00
BRAKE DRUM-(ALUM) 100.00 GENERATOR HOUSING 45.00
BRAKE DRUM-(STEEL) 85.00 GENERATOR STRAP 20.00
BRAKE MOUNT W/CAP 60.00 HAD GRIPS(ALUM) 35.00
BRAKE MOUNT BRACKET (LRG) 45.00 HAND LEVERS-start at 21.00
BRAKE MOUNT BRACKET(SML) 40.00 HAND LEVER PINS 2.25
BRAKE PEDAL(alum)-start at 40.00 HANDLEBAR(1PC) 60.00
BRAKE PEDAL(steel)-start at 40.00 HANDLEBAR(2PC) 70.00
BRAKE PLUNGER-2PC 25.00 HANDLEBAR(CUSTOM)w/riser 150.00
BRAKE PLUNGER END 10.00 HANDLEBAR RISER-1pc steel 45.00
BRAKE ROD-start at 20.00 HANDLEBAR RISER(ALUM)TALL 35.00
BRAKE ROTOR BRACKET 25.00 HANDLEBAR RISER(ALUM)SHRT 30.00
BREATHER TUBE 25.00 HANDLEBAR-APEHANGER 80.00
CALIPER(1PC)FRONT/REAR 55.00 HANDLEBAR CLAMP(POT METAL) 40.00
CALIPER Y2K(2PC)FRONT 100.00 HEAD BOLTS 4.00
CALIPER Y2K(2PC)REAR 150.00 HIGHWAY BAR 50.00
CALIPER MOUNT ARMS 25.00 HORN BRKT 20.00
CALIPER BOLTS-start at 3.00 HORN COVER 25.00
CALIPER DUST COVER 10 `.00 HORNS-start at 75.00
CALIPER FITTINGS 2.00 HUB(ALUM) 85.00
CALIPER MOUNT(DYNA) 85.00 HUB(STEEL) 65.00
CALIPER MOUNTS-start at 70.00 HUB CAP 50.00
CALIPER SPACER 16.00 HUB DOME(ALUM) 45.00
CAM COVER(sportster) 120.00 HUB STAR 15.00
CAM COVER(old style) 115.00 INSTRUMENT CUP 25.00
CAM COVER(cone) 75.00 INSTRUMENT RING SPACER 30.00
CARB.BODY-start at 75.00 INTAKE MANIFOLD-start at 35.00
CARB.TOP-start at 25.00 KICKER ARM 25.00
CARB.BOTTOM-start at 15.00 KICKER BLOCK 18.00
CHAIN ADJ.(2PC) 7.50 KICKER COVER-start at 75.00
CHAIN GUARDS-start at 45.00 KICKER COVER PLUG 8.00
CHOKE KNOBS 5.00 KICKER PEDAL 35.00
CLEVIS PINS 2.00 KICK STANDS-start at 35.00
CLUTCH ARM 20.00 KICKSTAND STOP 7.00
CLUTCH CABLE BRKT. 18.00 KICKSTAND SPRING 8.00
CLUTCH COVER 38.00 KICKSTAND SPRING STUD 2.00
CLUTCH COVER PLATE SPRING 7.50 KICKSTAND SPRING BRKT 20.00
CLUTCH RELEASE MOUNT 25.00 LICENSE FRAMES-start at 25.00
CLUTCH SPRING PLATE 25.00 LICENSE BACKING PLATES 25.00
COIL COVER 28.00 LIFTER BLOCKS(ALUM) 60.00
COIL SPRING 15.00 LIFTER BLOCKS(STEEL) 55.00
CONTROL CAPS 8.00 LIFTER BLOCKS(KNUCKLE) 65.00
CRASH BARS-start at 115.00 LIFTER BLOCKS(SPORT) 30.00
D-RINGS(ALUM) 45.00 LIFTER BLOCK SCREWS 2.00
D-RINGS(STEEL) 40.00 LOWER LEGS-start at 80.00
DASH PLATE 35.00 LOWER LEG CAP 8.00
DASH PANELS-start at 55.00 LIGHT BAR PLATES 75.00
DASH-cat eye- 100.00 LUGGAGE RACK-start at 75.00
DASH(2PC)FLT 325.00 LUG NUTS 4.00
DERBY COVER(ALUM) 26.00 MAGNETO HOUSING 45.00
DERBY COVER(POT METAL) 40.00 MASTER CYLINDERS 55.00
DIP STICK 15.00 MASTER CYLINDER CAP 15.00
DISTRIBUTOR CAP 20.00 MIRROR ASSEMBLY(4PC) 15.00
DISTRIBUTOR BASE 35.00 MIRROR SPACER 2.00
DISTRIBUTOR TOP 25.00 MIRROR STEMS 15.00
DOGBONE 23.00 MOTOR MOUNTS-start at 25.00
EXAUST BARS-start at 45.00 MUFFLER BARS 50.00
NUTS-start at 1.75 SCHOCK BOLTS 4.00
OIL FILTER MOUNT-start at 30.00 SCHOCK CUPS 15.00
OIL LINES-start at 22.00 SCHOCK SPRINGS 25.00
OIL TANK(HORSE SHOE) 175.00 STABILIZER BAR 30.00
OIL TANK (ROUND,ALUM) 150.00 SISSY BAR-start at 55.00
OIL TANK (SPORTSTER) 150.00 SISSY BAR MNT BRACKET 40.00
OIL TANK(SQUARE) 150.00 SKID PLATE 45.00
OIL TANK PLUG 9.00 SLIDER CANS 30.00
OIL TANK STRAP 30.00 SOLINOID COVER 30.00
PASSENGER PEG MNT BARS 42.00 SPOTLIGHT MOUNT BRACKET 35.00
PET-COCK W/PLATE 10.00 SPOTLIGHT BUCKET 28.00
POINTS COVER(ALUM) 22.00 SPOTLIGHT FRAME 75.00
PRIMARY-INNER 175.00 SPROCKET COVER 80.00
PRIMARY-OUTER 150.00 SPROCKET PULLEY 150.00
PRIMARY-OUTER W/DERBY 175.00 STARTER HOUSING 40.00
PRIMARY INSPECTION PLATE 25.00 STARTER NOSE 40.00
PRIMARY PLUGS 10.00 STEM NUT 9.00
PUSH ROD ASSEMBLY(3PC) 40.00 SWING ARM 200.00
RACHET COBER 75.00 SWING ARM(DYNA) 330.00
REAR TAG FRAME 75.00 SWING ARM(SOFTTAIL) 450.00
REGULATOR BRACKET 28.00 SWITCH HOUSING 20.00
REGULATOR END CAP 35.00 SWITCH HOUSING(TALL) 22.00
RISER CAPS 9.00 SWITCH CONTROL CAP 15.00
RISER WASHER 3.00 TIN SET(3PC,HERITAGE) 85.00
ROCKERBOX(SHOVELHEAD) 135.00 TOE-HEEL SHIFTER 38.00
ROCKERBOX(NUCKLE) 135.00 TOMBSTONE TAIL LIGHT 40.00
ROCKERBOX(SPORT) 135.00 TOOL BOX(2PC) 75.00
ROCKERBOX(3PC) 110.00 TOOL BOX PLATE 40.00
ROCKERBOX(3PC)-ind.pcs. 40.00 TRANSMISSION BODY 250.00
ROCKERBOX(PAN-ALUM) 80.00 TRANSMISSION COVER 80.00
ROCKERBOX(PAN-STEEL) 65.00 TRANSMISSION DIP STICK 15.00
ROCKER BUTTONS 7.00 TRANS END PLATE 60.00
S&S COVER 50.00 TRIPLE TREE(ALUM) 80.00
S&S BACKING PLATE 45.00 TRIPLE TREE(STEEL) 70.00
SADDLEBAG BRACKETS 50.00 TRIPLE TREE(CUSTOM) 100.00
SADDLEBAG BOLTS 4.00 TRIPLE TREE COVER 30.00
SADDLEBAG FRAMES 65.00 TURNBUCKLE 20.00
SADDLEBAG RAILS 45.00 WASHERS-start at 1.00
SEAT FRAME 115.00 WIND DEFLECTOR(SMALL) 60.00
SEAT HANDLES 25.00 WIND DEFLECTOR(LARGE) 35.00
SEAT HINGE(2PC W/HINGE) 30.00 WINDSHIELD BRACING(SQ) 35.00
SHIFT ARMS-start at 20.00 WINDSHIELD BRACING(CURVED) 45.00
SHIFT LINKAGE(5PC) 21.00 WHEEL RIMS(SPOKE)-start at 125.00
SHIFT MOUNT BRACKET 35.00 WHEELS(ALUM)start at 250.00
SHROUD-HEADLIGHT 95.00
POLISHING ONLY COMMON PRICE QUOTE
BRAKE ROTORS 50.00 BOLTS-start at 1.00
ENGINE CASES 400.00 CALIPER(1PC)FRT/REAR 55.00
CYLINDER JUGS(2) 90.00 CAMCOVER(SPORTSTER) 120.00
HEADS(2) 90.00 CAMCOVER(CONE) 75.00
3PC OIL PUMP 75.00 CAMCOVER(KIDNEY) 115.00
SPEEDO HOUSING 9.00 CLUTCH RELEASE MOUNT 25.00
TRANSMISSION CASE 125.00 LOWER LEGS-start at 80.00
PRIMARY-INNER 115.00 LOWER LEG CAPS 8.00
PRIMARY-OUTER 90.00 MASTER CYLINDERS 55.00
NUTS-start at 1.00
SWITCH HOUSINGS(4) 80.00
This is just a price guide, prices may be higher due to condition on inspection. Prices subject to change without notice.
Another Place in Florida
Nice work brother...
