Maldev Posted February 4, 2013 Share Posted February 4, 2013 Guess what this Indian Motorcycle tool is and its use. Quote Link to comment Share on other sites More sharing options...
Blademaker Posted February 4, 2013 Share Posted February 4, 2013 Ummm, oil filter wrench? Quote Link to comment Share on other sites More sharing options...
mycorn Posted February 4, 2013 Share Posted February 4, 2013 pulley holder for torquing the engine nut? Quote Link to comment Share on other sites More sharing options...
CKelly Posted February 4, 2013 Share Posted February 4, 2013 It's looks to be a raiser clamp, we use them to hold pipe up when it goes thru the floors of a building...............A clutch hub holder 2 Quote Link to comment Share on other sites More sharing options...
darkrider Posted February 4, 2013 Share Posted February 4, 2013 we're not idiots thats a portable potty tool common in most older motorcycle tool kits. Its also popular among hikers, farmers, golfers, etc. where restrooms are not close by. You just take a zip lok bag or one of your plastic wal mart bags and put it inside the ring kinda like a trash can liner and then squat down and use the handle to hold the ring up to your bottom. When your done doing your business you close the bag up and tie it to your belt loop and dispose of it later in a trash can. 2 Quote Link to comment Share on other sites More sharing options...
lschultz Posted February 4, 2013 Share Posted February 4, 2013 Well I'll be. I did not know that. Shows what I know. Where did you learn this? It is a thingamachathei for that uh whats it called. I have to think on this. It is right on the tip of me tongue. Quote Link to comment Share on other sites More sharing options...
indiantoo Posted February 4, 2013 Share Posted February 4, 2013 Some type of welding jig for spacing purposes Quote Link to comment Share on other sites More sharing options...
CKelly Posted February 4, 2013 Share Posted February 4, 2013 we're not idiots thats a portable potty tool common in most older motorcycle tool kits. Its also popular among hikers, farmers, golfers, etc. where restrooms are not close by. You just take a zip lok bag or one of your plastic wal mart bags and put it inside the ring kinda like a trash can liner and then squat down and use the handle to hold the ring up to your bottom. When your done doing your business you close the bag up and tie it to your belt loop and dispose of it later in a trash can. I was thinking the same thing but I didn't see a chair to sit on. That must be for the young people. Us old farts would need a chair. Also it would help to be a little bigger. I can't see as good as I use to. Quote Link to comment Share on other sites More sharing options...
CKelly Posted February 4, 2013 Share Posted February 4, 2013 My Mom stop taking calls about me along time ago. All she use to say she did the best she could. Quote Link to comment Share on other sites More sharing options...
CKelly Posted February 4, 2013 Share Posted February 4, 2013 It's looks to be a raiser clamp, we use them to hold pipe up when it goes thru the floors of a building...............A clutch hub holder If it isn't that, it may be come one soon..........The Junkman is always looking for something to do. Quote Link to comment Share on other sites More sharing options...
hasbin Posted February 4, 2013 Share Posted February 4, 2013 Oh oh oh oh oh, I know mister Kotter...... Quote Link to comment Share on other sites More sharing options...
injun46 Posted February 4, 2013 Share Posted February 4, 2013 Something to do with the clutch or the comp. sprocket. Quote Link to comment Share on other sites More sharing options...
Maldev Posted February 4, 2013 Author Share Posted February 4, 2013 Hasbin is smarter than he looks. 2 Quote Link to comment Share on other sites More sharing options...
hasbin Posted February 4, 2013 Share Posted February 4, 2013 Hasbin is smarter than he looks. Ok before you boyz start wrapping shit around your pulley's. First I took a 3' length of 1-1/2" x 3/16" strap & clamped it to an old 33T pulley, I fired up the "rose-bud" torch and got the band red hot at the leading edge & rotated the pulley (go slow) so it conformed to the pulley, I cut it a bit short (so I could use it on a 32T-34T pulley. Then I cut it in half and welded the ears on the ends (this should be done when wrapped around a pulley to get the proper angle) I cut an old belt to wrap around the pulley & pulled the new holder on & tightened-up, around the belt & pulley, I then went to the scoot to see where the handle should hit, measured, cut & welded, I don't know if the lil braces from the handle to the clamp are needed, but I always "over engineer" the shit I make. In the 2nd pic it shows the handle resting on the frame (for installing) When removing it rests on the top of the swing-arm with a 34T pulley Cost= $6.00 for material, 3/4 hr shop rate w/welding $75.00 Total $81.00 Priceless when nobody's around to help 2 Quote Link to comment Share on other sites More sharing options...
darkrider Posted February 5, 2013 Share Posted February 5, 2013 looks great! the only thing I would do differant is use wing nuts on the 2 bolts to make it easier and quicker to tighten the bag in place. they dont have to be that tight unless you really had ro go alot Quote Link to comment Share on other sites More sharing options...
CHIEF DOC 99 Posted February 5, 2013 Share Posted February 5, 2013 Maybe make a nice neck brace shackle for some body....does it come in flat hot rod black? Quote Link to comment Share on other sites More sharing options...
IndianTrue Posted February 5, 2013 Share Posted February 5, 2013 Ok before you boyz start wrapping shit around your pulley's. First I took a 3' length of 1-1/2" x 3/16" strap & clamped it to an old 33T pulley, I fired up the "rose-bud" torch and got the band red hot at the leading edge & rotated the pulley (go slow) so it conformed to the pulley, I cut it a bit short (so I could use it on a 32T-34T pulley. Then I cut it in half and welded the ears on the ends (this should be done when wrapped around a pulley to get the proper angle) I cut an old belt to wrap around the pulley & pulled the new holder on & tightened-up, around the belt & pulley, I then went to the scoot to see where the handle should hit, measured, cut & welded, I don't know if the lil braces from the handle to the clamp are needed, but I always "over engineer" the shit I make. In the 2nd pic it shows the handle resting on the frame (for installing) When removing it rests on the top of the swing-arm with a 34T pulley Cost= $6.00 for material, 3/4 hr shop rate w/welding $75.00 Total $81.00 Priceless when nobody's around to help The braces/gussets are what tells me it is well engineered and won't bend/break while being used. Good job. Quote Link to comment Share on other sites More sharing options...
hasbin Posted February 5, 2013 Share Posted February 5, 2013 looks great! the only thing I would do differant is use wing nuts on the 2 bolts to make it easier and quicker to tighten the bag in place. they dont have to be that tight unless you really had ro go alot Wing-nutz won't work, It has to hold back 150lbs, I use a 3/8" air ratchet (faster than wing-nutz) Maybe make a nice neck brace shackle for some body....does it come in flat hot rod black? If you know somebody with a "pencil-neck" I guess it would work, Comes in whatever color I have laying around Quote Link to comment Share on other sites More sharing options...
Clan Chief Posted February 5, 2013 Share Posted February 5, 2013 Guess what this Indian Motorcycle tool is and its use. Ummmmm Last Resort ???? Quote Link to comment Share on other sites More sharing options...
Ariel Melecio Posted February 5, 2013 Share Posted February 5, 2013 have you one to hold clutch hub? if so can you post a pic? Quote Link to comment Share on other sites More sharing options...
hasbin Posted February 5, 2013 Share Posted February 5, 2013 have you one to hold clutch hub? if so can you post a pic? I will have one posted this afternoon, Do a search on "clutch-hub tool, I know there are some pics. & I do have a few left Quote Link to comment Share on other sites More sharing options...
badndn Posted February 5, 2013 Share Posted February 5, 2013 Ok before you boyz start wrapping shit around your pulley's. First I took a 3' length of 1-1/2" x 3/16" strap & clamped it to an old 33T pulley, I fired up the "rose-bud" torch and got the band red hot at the leading edge & rotated the pulley (go slow) so it conformed to the pulley, I cut it a bit short (so I could use it on a 32T-34T pulley. Then I cut it in half and welded the ears on the ends (this should be done when wrapped around a pulley to get the proper angle) I cut an old belt to wrap around the pulley & pulled the new holder on & tightened-up, around the belt & pulley, I then went to the scoot to see where the handle should hit, measured, cut & welded, I don't know if the lil braces from the handle to the clamp are needed, but I always "over engineer" the shit I make. In the 2nd pic it shows the handle resting on the frame (for installing) When removing it rests on the top of the swing-arm with a 34T pulley Cost= $6.00 for material, 3/4 hr shop rate w/welding $75.00 Total $81.00 Priceless when nobody's around to help Who did you hire to weld it? hehe Quote Link to comment Share on other sites More sharing options...
Satuit Posted February 6, 2013 Share Posted February 6, 2013 It's a henway. Quote Link to comment Share on other sites More sharing options...
Travlur Posted February 12, 2013 Share Posted February 12, 2013 Naw... I've got a henway, and it don't look nuttin like that! Quote Link to comment Share on other sites More sharing options...
Harleynot Posted February 12, 2013 Share Posted February 12, 2013 (edited) It's a henway. ...how much does a henway ? ..signed........ Edited February 13, 2013 by harleynot Quote Link to comment Share on other sites More sharing options...
